20 years agoHas anyone successfully used a LAN91C111 d-card...
I've read everything I can find on the forum about this topic, and so far the answer seems to be no. One guy got it to work on a custom board, and Nate Knight got it to work on a DSP board, but I...
20 years ago --- Quote Start --- originally posted by tns1@Nov 7 2005, 04:04 PM connect pins# be0,# be1 to the same named module port pins.
connect pins a1,a2,a3 to module pins a2,a3,a4.
tie pins a8,a9 high, all remaining address pins low.
irq and reset connected to obvious pins.# ior,# iow to# rd,#wr.# ads, aen low, lclk,# be2,#be3 high.
with the address lines connected as described, your registers should be on 32bit boundaries: base+0,base+4,base+8,etc.
as a test try to read the bsr:
write 0x0003 to base+0xe, then you should read something like 0x339n from base+0xa. you may have to use 0x1c,0x14 instead of 0xe,0xa depending on if you have used any of the built-in macros to do the job. once this works, you will know what kind of changes will be needed to the driver - mainly shift and mask.
the reason for using native addressing is to prevent the nios from doing two reads when you really want just one (data fifo access) . use a scope to see if you need to worry - it may not happen under 5.0. --- Quote End --- Sweet, I got it working. Nate Knight's 16-bit-friendly driver helped out too, although I had to fix the offsets for the IORD_8DIRECT calls and use regular IORD/WR for the rest. The IORD/WR calls work off Base+0, Base+2, Base+4 etc too which was nice. For the IORD_8DIRECT I had to use Base + (x * 4) for the low byte and Base + (x * 4 + 1) for the high byte. Next step is to stack two of these puppies and get three interfaces running simultaneously on the board. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/cool.gif Thanks!
