14 years agoHardware Interrupt
Hello everyone, i have a simple question but i am a beginner and after searching the web for a day an reading nearly all nios documentations i decided to use a Forum. I hope someone can help me. ...
14 years agoi have a code example.
it nearly works, It jumps in the IRS but dont know wicht key were pushed dont know why :-/
.equ STACK_SIZE, 0x400# stack size
.equ PUSHBUTTON_BASE, 0x10000050
.data
TST_PAK1:
.word 0x11112222# test data
STACK_END:
.word 0xFFFFFFFF# end of stack
.skip STACK_SIZE# stack area filled with 0
# Exception# #
.section .exceptions, "ax" # Fixierung der Routine
subi sp, sp, 4 # Stacksicherung
stw r13, (sp)
subi sp, sp, 4
stw r4, (sp)
subi sp, sp, 4
stw r3, (sp)
ISR:
movia r5, 0x810
rdctl et, ctl4 # Überprüfung auf Interrupt
beq et, r0, SKIP # Interrupt ist weg, raus aus der Exception
subi ea, ea, 4 # PC Anpassung
andi r13, et, 0b1000
bne r13, r0, IRQ1_ISR# Test ob es IRQ1 aktiv ist
andi r13, et, 0b0010
bne r13, r0, IRQ3_ISR# Test ob es IRQ3 aktiv ist
br SKIP
IRQ1_ISR: # Erste Taste gedrückt
movia r4, 15
stw r4, (r5)
br SKIP
IRQ3_ISR: # Vierte Taste gedrückt
stw r0, (r5)
movia r3, 15
SKIP: # Springt zum Ende der interrupt-service routine
ldw r3, (sp)
addi sp, sp, 4
ldw r4,(sp)
addi sp, sp, 4
ldw r13, (sp)
addi sp, sp, 4
eret # Raus aus der Exception
# End Exception #
# TEXT SECTION
# Executable code follows
.global _start
.text
_start:
movia sp, STACK_END # load data section's start address
addi sp, sp, STACK_SIZE # stack start position should
# begin at end of section
subi sp, sp, 4
stw r15, (sp)
subi sp, sp, 4
stw r16, (sp)
movi r16, 0x10# Interrupt starten
movi r15, 1
wrctl ctl3, r16
wrctl ctl0, r15
# Taster Interrupts aktivieren
movia r16, 0x0840
movi r15, 0x9# Maske für die Interrupts 1001 => 0x9
stw r15, 8(r16)# Maske in der Adresse von Tastern reinschreiben um Interrupts aktivieren
ldw r16, (sp) # Stack
addi sp, sp, 4
ldw r15, (sp)
addi sp, sp, 4
br endloop
endloop:
br endloop # that's it
.end
