21 years ago
hardware configuration
At the moment I am working with the cycloneII 2c35 devel. kit. On the board is the Max7000. In the configuration I plan, there will only be a SRAM, LAN, SPI and a flash. So no change of the configuration is required after the design is finished.
Can the Max7000 be omitted from a no more changing design? Does this require a modification of the software or changes in the NIOSII settings?
thanks for your help in advance
andy
1 Reply
    FPGA is based on SRAM tehnology. Its Functon will disappear when Poweroff. So it is recommand using a "ROM" to config FPGA while poweron. The ROM can be EPC or EPCS from Altera or like Nios kit using Flash and Configure controller (CPLD). So do you konw what to do?
