20 years agoHAL, LWIP and fragmentation support
Dear all,
I'm taking a look to the LWIP source code, and in particular to the web server example for the Altera HAL distributed in the Forum . In particular, I'm looking to the ip_reass_timer() function, called inside main(). here is the main loop: while(1)
//0.6.4 lan91c111if_service(netif);
lan91c111if_service(&netif);
now = get_milliseconds();
if (now - lasttime > TCP_TMR_INTERVAL) {
lasttime = now;
tcp_tmr();
if (++i==50) {
//etharp_tmr();
i=0;
# if IP_REASSEMBLY
if (++j==1000) {
ip_reass_timer();
j=0;
} # endif
} The reassembly timer is here (see src/core/ipv4/ip_frag.c): void
ip_reass_timer(void *arg)
(void)arg;
if (ip_reasstmr > 1) {
ip_reasstmr--;
sys_timeout(IP_REASS_TMO, ip_reass_timer, NULL);
} else if (ip_reasstmr == 1)
ip_reasstmr = 0;
} it seems to me that the reassembly timer should be called once a second (IP_REASS_TMO is 1000). Is that right? PJNo RepliesBe the first to reply
