HAL API for the Generic Serial Flash Interface FPGA IP, 'altera_safeclib'
- 4 years ago
Hi Meenalkb,
To enable the Generic Serial Flash Interface (GSFI) use the HAL API and follow the below steps in Eclipse.
- BSP Editor->Nios II
- file paths of .sopcinfo and .bsp (new or old) in the open BSP window and click on open.
- A platform design window will be open in which you select the BSP software packages option. In that, just enable the altera_safeclib option.
- Select Generate BSP.
once the BSP generation is completed. Check in the drivers->inc and drivers->src folders. for
https://www.intel.com/content/www/us/en/docs/programmable/683419/22-1-20-1-1/nios-ii-hal-driver.html
- intel_generic_serial_flash_interface_top.h
- intel_generic_serial_flash_interface_top.c
hi
please share BSP editor version details, platform design screen shot and I am sharing the screen shot of that.
It was the same problem as what I described (community.intel.com/t5/Nios-II-Embedded-Design-Suite/HAL-API-for-the-Generic-Serial-Flash-Interface-FPGA-IP-altera/m-p/1393376#M51250). Can we arrange a call to discuss?
- HAlex4 years ago
Hello
Any updates with this issue?
I also have exactly the same problem.
Is it maybe because I am using Quartus Prime 21.1.0 Standard (and not a PRO) edition?
Thank you
Alex
