16 years agoh264 for uclinux on cycloneIII 3C25
Hi, I want to execute h264 code from (url: iphome.hhi.de/suehring/tml/download/old_jm/jm16.2.zip) into uclinux with a Xenomai patch. I used Nios2-ide for genrating the .elf file for the...
16 years agoUnder gcc/linux, the executable can have any extension, so it's not a problem per se.
It's problably a side effect of the build script. However, maybe it's worth taking a look a it. I understood that you're using gcc in Linux. What I meant is that, by the looks of it, whoever wrote the code was targeting just WIN32 and that may be the origin of your obscure problems. From the __STDC_VERSION__ < 199901L condition, it also looks like the author was targeting C99. Yet another dumb suggestion: try using the "c99" command to compile, instead of "gcc" -- it's an alias to gcc which makes it behave as a strict C99 compiler.
