16 years agoh264 for uclinux on cycloneIII 3C25
Hi, I want to execute h264 code from (url: iphome.hhi.de/suehring/tml/download/old_jm/jm16.2.zip) into uclinux with a Xenomai patch. I used Nios2-ide for genrating the .elf file for the...
16 years agothanks rbugalho,
first, thx for your prompt response. I want to clarify something: yes the code is targeted to a Win32 compiler. but i'v compiled this code with gcc in linux (the only suspect thing is that the executable generated after the compilation was a .exe file ... is that normal??). the problem is only in cross compilation with Nios2-ide. any other suggestions?
