21 years agogtf-launch error while building library
I'm getting an error using Build->Library that indicates gtf-lauch is not found which results in an Error 127 while trying to later open the output file. I've verified that gtf-lauch exists ...
19 years agoI also had the same Issue, And I did the same thing as mentioned below from jim_xie. That worked.. Thanx man!!
--- Quote Start --- originally posted by jim_xie@Oct 27 2005, 02:44 PM i meet this probelem too , and my solution is :open the gtf-launch file ,then delete the first blank character of the first line , then save the file;
i don't know why? ,maybe somebody can explain it.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10618)
--- quote end ---
--- Quote End ---
