21 years agogtf-launch error while building library
I'm getting an error using Build->Library that indicates gtf-lauch is not found which results in an Error 127 while trying to later open the output file. I've verified that gtf-lauch exists ...
21 years agoQuartus 5 Nios II 5
Windows XP Pro SP2 Mapped local Directory as Drive T: eg: C:/Project/test when I build eCos on a mapped drive (t:) I always get make[1]: Leaving directory `/cygdrive/t/Software/eCos/examples/example_build/hal/nios2/arch/current' /cygdrive/t/Software/eCos/examples/example_install/gtf-launch: not found make[1]: *** [/cygdrive/t/Software/eCos/examples/example_install/include/cyg/hal/system.h-t] Error 127 make: *** [build] Error 2 make: Leaving directory `/cygdrive/t/Software/eCos/examples/example_build' when I build it from C:/Project/test It works:- Why ? I have tryed changing permissions on the mapped drive, didn't help
