21 years agogtf-launch error while building library
I'm getting an error using Build->Library that indicates gtf-lauch is not found which results in an Error 127 while trying to later open the output file. I've verified that gtf-lauch exists ...
21 years agoI also encountered this annoying "gtf-launch" problem, excactly as described by StefanLevie.
I use Quartus 5.0 and Nios 5.0 and have never installed uclinux, so uclinux cannot be the problem. Has anybody found a solution yet?
