21 years agogtf-launch error while building library
I'm getting an error using Build->Library that indicates gtf-lauch is not found which results in an Error 127 while trying to later open the output file. I've verified that gtf-lauch exists ...
21 years agoHi:
there are two possiblities: one is that your PC has been affected virus , the second is that you should fixed the " make " command in the NIOS IDE to "make INSTALL_DIR=<PATH>" ,i think you success if you do so
