21 years agogtf-launch error while building library
I'm getting an error using Build->Library that indicates gtf-lauch is not found which results in an Error 127 while trying to later open the output file. I've verified that gtf-lauch exists ...
21 years agoI suspect that the connection to ucLinux may be a red herring here. However to be sure have you tried the following:
1. uninstall eCos, ucLinux, the Nios II kit, and Quartus. 2. reinstall everything except ucLinux.
