21 years agogtf-launch error while building library
I'm getting an error using Build->Library that indicates gtf-lauch is not found which results in an Error 127 while trying to later open the output file. I've verified that gtf-lauch exists ...
21 years agoI also meet this problem!
I can't build uclinux and ecos2.0! make[1]: Entering directory `/cygdrive/e/altera/kits/nios2/examples/MyProject/Redboot/redboot_build/hal/nios2/arch/current' /cygdrive/e/altera/kits/nios2/examples/MyProject/Redboot/redboot_install/gtf-launch --gtf=`cygpath -m /cygdrive/e/altera/kits/nios2/components/ecos/ecos-current/packages/hal/nios2/arch/current/gtf/system.h.gtf` --output-directory=`cygpath -m /cygdrive/e/altera/kits/nios2/examples/MyProject/Redboot/redboot_install/include/cyg/hal/` make[1]: Leaving directory `/cygdrive/e/altera/kits/nios2/examples/MyProject/Redboot/redboot_build/hal/nios2/arch/current' /cygdrive/e/altera/kits/nios2/examples/MyProject/Redboot/redboot_install/gtf-launch: not found make: Leaving directory `/cygdrive/e/altera/kits/nios2/examples/MyProject/Redboot/redboot_build'
