21 years agogtf-launch error while building library
I'm getting an error using Build->Library that indicates gtf-lauch is not found which results in an Error 127 while trying to later open the output file. I've verified that gtf-lauch exists ...
21 years agoThanks. I'm running Windows 2000 SP4 and have tried this on the local drive as well as a networked drive. Do you typically use Windows XP then?
If I find a solution, I'll post it. Anyone else encounter and solve this problem - other than an OS upgrade? Stefan
