Zeid's avatar
Zeid
7 years ago
Greetings, How can I know what are the libraries used in NIOS II projects?
I am able to build an embedded system but I do not know how to use the libraries.
Is there a good manual that helps me to know which libraries should be used with certain embedded hardware ? and the syntax of using it , for example PIO in Qsys, can be programmed to send the data using the library IOWR_ .... and IORD....
Thanks in advance
