Got Stuck while doing NIOS II
I'm New to this field. i've to make communication interface between the Hardware(FPGA) with Software(GUI). I'm Using Cyclone V FPGA 5CEFA7F27I7. This FPGA does not contain Any Soc in it so we are using, Micron SDRAM(DDR3), NandFlash 16GBx8, DP83867(Ethernet physical Transreceiver) to make the communication with GUI through Ethernet.
Should i have to use NIOS II or Eclipse?
can i able to get some guidelines or easy materials which can be understandable by fresher?
Thank you for the help
Prajwal RJ
- EBERLAZARE_I_Intel
We suggest that you start with the Nios V if you're new, and test our design by following our handbook with the OCRAM booting:
Are you also new to Quartus?
Do you have any further questions?
