21 years agoGNU tools for NiosII
Hello, I am looking for information about application building without using NiosII IDE and Altera HAL. I'd like use GNU tools only. Does anybody have experiences with direct using GNU...
21 years agoThe simplest thing you can do to build your application without the ide is to create a shell script containing something like:
nios2-elf-gcc -O2 -o <project.elf> <source file.c> <another source file.c> Of course you can use options other than -O2 if appropriate. You'll need some startup code, so you should probably copy crt0.S from the HAL into your project before modifying it, and it will be easier to start from a HAL generated linker script.
