20 years agoGNU Cross compiler for NIOS II
Hi, I am working on NIOS II processor. Could any one send GNU cross compiler / Tool chain for NIOS II embedded processor. I want to compile U-boot for NIOS II, I already have tool chain fo...
20 years agoHi hippo,
Thanks for your valuable guidance and information. Let me try and get back to you. thanks Vijay --- Quote Start --- originally posted by hippo@Jul 11 2006, 08:48 PM you can find address map from sopc builder of your project.u-boot will be linked to somewhere near the end of sdram.
check with nios2-linux-uclibc-objdump -h u-boot, to see the vma.
first try to run u-boot from sdram, it is similar to tryout linux, but u-boot replace zimage.
http://nioswiki.jot.com/wikihome/operating...s/tryoutuclinux (http://nioswiki.jot.com/wikihome/operatingsystems/tryoutuclinux)
if it works, then you can program it to flash,
http://nioswiki.jot.com/wikihome/operating...flashprogrammer (http://nioswiki.jot.com/wikihome/operatingsystems/flashprogrammer)
it will insert an altera supplied cfi boot loader, which will copy u-boot image from flash to sdram, and jump start on sdram to run u-boot.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16803)
--- quote end ---
--- Quote End ---
