21 years agoglobal pointer relative offset
The linker gives me this message: “global pointer relative offset 34384 at address 0x008adcc8 out of range -32678 to 32767 » I don’t see what does that mean ? When I click on the error lin...
21 years agoAgain me
The blocking point seems the location or the size of the MW table "__MW_APP_TAB__" I modified the STACKSIZE in the ecos_mw_app.h, and I am able to compile without –G0 Here below an extract of the readelf file sorted by address. The _MW_APP_TAB_ area is located in the area pointed by gp The previous value of STACKSIZE was 65536 I modified in 15000 for this test. What is the best way now ? to modify the STACKSIZE or to modify the location of "__MW_APP_TAB__" Num Value Size Type Bind Vis Ndx Name --------------------------------------------------------------- 925 008685d4 2 OBJECT LOCAL DEFAULT 6 id 926 008685d8 4 OBJECT LOCAL DEFAULT 6 domainname 933 008685dc 4 OBJECT LOCAL DEFAULT 6 init.1 1686 008685e0 4 OBJECT GLOBAL DEFAULT 6 clipregion 953 008685e4 4 OBJECT LOCAL DEFAULT 6 nextimageid 1795 008685e8 4 OBJECT GLOBAL DEFAULT 6 gr_mode 2234 008685ec 6 OBJECT GLOBAL DEFAULT 6 mwstdpal1 1015 008685f4 4 OBJECT LOCAL DEFAULT 6 timerlist 1264 008685f8 12 OBJECT GLOBAL DEFAULT 6 _net_init_tab0x50000000mb 1945 008685f8 0 OBJECT GLOBAL DEFAULT 6 __NET_INIT_TAB__ 1675 00868604 12 OBJECT GLOBAL DEFAULT 6 _net_init_tab0x60000000de 2168 00868610 12 OBJECT GLOBAL DEFAULT 6 _net_init_tab0x70000000if 2474 0086861c 12 OBJECT GLOBAL DEFAULT 6 _net_init_tab0x84000000in 2254 00868628 12 OBJECT GLOBAL DEFAULT 6 _net_init_tab0x88000000do 2040 00868634 12 OBJECT GLOBAL DEFAULT 6 _net_init_tab0x88000001do 1588 00868640 12 OBJECT GLOBAL DEFAULT 6 _net_init_tab0x88000001do 2439 0086864c 12 OBJECT GLOBAL DEFAULT 6 _net_init_tab0x88000002ro 1217 00868658 15260 OBJECT GLOBAL DEFAULT 6 _mw_app_ECOS_MW_NANOX_PRI 1228 00868658 0 OBJECT GLOBAL DEFAULT 6 __NET_INIT_TAB_END__ 1510 00868658 0 OBJECT GLOBAL DEFAULT 6 __MW_APP_TAB__ 1199 0086c1f4 15260 OBJECT GLOBAL DEFAULT 6 _mw_app_ECOS_MW_NANOX_PRI 1127 0086fd90 0 OBJECT GLOBAL DEFAULT 6 __DEVTAB__ 1153 0086fd90 0 OBJECT GLOBAL DEFAULT 6 __MW_APP_TAB_END__ 1884 0086fd90 28 OBJECT GLOBAL DEFAULT 6 uart1_io 1385 0086fdac 28 OBJECT GLOBAL DEFAULT 6 jtag_uart_io 2172 0086fdc8 28 OBJECT GLOBAL DEFAULT 6 lcd_display_io 2291 0086fde4 28 OBJECT GLOBAL DEFAULT 6 tty_io_diag 2016 0086fe00 28 OBJECT GLOBAL DEFAULT 6 haldiag_io0 2150 0086fe1c 0 OBJECT GLOBAL DEFAULT 6 __DEVTAB_END__ 2242 0086fe1c 64 OBJECT GLOBAL DEFAULT 6 dev_fste 2451 0086fe1c 0 OBJECT GLOBAL DEFAULT 6 cyg_fstab 1272 0086fe5c 0 OBJECT GLOBAL DEFAULT 6 cyg_mtab 1810 0086fe5c 28 OBJECT GLOBAL DEFAULT 6 dev_mte 2396 0086fe5c 0 OBJECT GLOBAL DEFAULT 6 cyg_fstab_end 1131 0086fe78 224 OBJECT GLOBAL DEFAULT 6 cyg_mtab_extra 2019 0086ff58 16 OBJECT GLOBAL DEFAULT 6 lan91c111_netdev 2137 0086ff58 0 OBJECT GLOBAL DEFAULT 6 cyg_mtab_end 2313 0086ff58 0 OBJECT GLOBAL DEFAULT 6 __NETDEVTAB__ 1194 0086ff68 0 OBJECT GLOBAL DEFAULT 6 cyg_nstab 1609 0086ff68 28 OBJECT GLOBAL DEFAULT 6 cyg_bsd_nste 2122 0086ff68 0 OBJECT GLOBAL DEFAULT 6 __NETDEVTAB_END__ 7 0086ff84 0 SECTION LOCAL DEFAULT 7 1804 0086ff84 0 OBJECT GLOBAL DEFAULT 6 cyg_nstab_end 1991 0086ff84 4 OBJECT GLOBAL DEFAULT 7 startup_thread 1995 0086ff84 0 NOTYPE GLOBAL DEFAULT ABS __bss_start 2260 0086ff84 0 NOTYPE GLOBAL DEFAULT ABS _edata 65 0086ff88 4 OBJECT LOCAL DEFAULT 7 lan91cxx_interrupt_handle 102 0086ff8c 4 OBJECT LOCAL DEFAULT 7 _no_data 113 0086ff90 1 OBJECT LOCAL DEFAULT 7 fileio_initializer 2469 0086ff94 4 OBJECT GLOBAL DEFAULT 7 idle_thread_loops 2430 0086ff98 8 OBJECT GLOBAL DEFAULT 7 _ZN10Cyg_Thread17exceptio 1166 0086ffa0 4 OBJECT GLOBAL DEFAULT 7 _ZN13Cyg_Interrupt8dsr_li -------------------- 1017 008702b0 8 OBJECT LOCAL DEFAULT 7 current_time 1029 008702b8 4 OBJECT LOCAL DEFAULT 7 cyg_libc_atexit_handlers_ 40 008702bc 15000 OBJECT LOCAL DEFAULT 7 startup_stack 1330 00870324 0 NOTYPE GLOBAL DEFAULT ABS _gp 1248 00873d54 240 OBJECT GLOBAL DEFAULT 7 startup_thread_obj 66 00873e44 28 OBJECT LOCAL DEFAULT 7 lan91cxx_interrupt
