21 years agoglobal pointer relative offset
The linker gives me this message: “global pointer relative offset 34384 at address 0x008adcc8 out of range -32678 to 32767 » I don’t see what does that mean ? When I click on the error lin...
21 years agoThanks for your help,
Yes I try to compile the eCos library with microwindows But the modification of the debug or optimization options produce the same message Modification of the size of some network buffers also With the “Build Microwindows eCos support” selected only the library compilation is ok, But adding the “Build complete eCos+Microwindows application” I don’t have success. I use the default options with the net package
