21 years agogive me a example
hello all: who can give me some examples about the use of the ecos on niosII IDE , whose contexts can include net or file operating. thanks in advance
21 years agoIf you're looking for a network example, there are instructions in the eCos getting started document that explain what is required to get the web server demo running. That might be a good starting point for you.
The getting started instructions also explain how you can use the IDE to debug eCos applications. If you're interested in building eCos applications from the IDE, take a look at the thread "eCos library IDE integration?" on this forum. Does this mean that you've solved your previous build problem? If so, can you post up your solution? That way others can benefit from what you've found.
