15 years agogit clone toolchain-mmu
I was trying to follow the (possibly old) instructions on the nioswiki to set up everything I need to build Linux to run on NIOS II with the default MMU (and some custom hardware). There is a command on there that does not seem to run anymore:
git clone git://sopc.et.ntust.edu.tw/git/toolchain-mmu.git Possibly this server is no longer there? I know I am probably asking something I will eventually learn by reading everything here, but I am feeling the pressure of time... Are there some more up-to-date instructions I should be following? Thanks.3 Replies
The Server is still there, I was having problem too today but it seems to work again.
Regards, Andreas - Altera_Forum
There is a more up to date file,
http://www.niosftp.com/pub/linux/nios2-linux-20100621.tar - Hippo - Altera_Forum
Hippo,
Do you mean that the git repositories are not the head of the current development? Just out of interest, how is development synchronized between developers? Regards, Andreas
