13 years agoGigabit Ethernet Interface (via Marvell 88E1111) with Cyclone IVE FPGA
Hello Everybody, I am using Altera DE2-115 Board (CyloneIVE device) and want to connect some other device running in Gbps via its Gigabit Ethernet Transceiver (Marvell 88E1111) interface. ...
12 years agoHi,
This means better is to buy IP cores. Anyway, i would like to modify the tutorial but first I didn't understand completely the application program written in C. I didn't understand which values are assigned to pointer *tse and how the address of pointer is incremented below? // Triple-speed Ethernet MegaCore base address volatile int *tse =(int *) 0x00102000; // Initialize the MAC address *(tse + 3) = 0x116E6001; *(tse + 4) = 0x00000F02; // Specify the addresses of the PHY devices to be accessed through MDIO interface *(tse + 0x0F) = 0x10; *tse + 0x10 = 0x11; // Write to register 20 of the PHY chip for Ethernet port 0 to set up line loopback *(tse + 0x94) = 0x4000; // Write to register 16 of the PHY chip for Ethernet port 1 to enable automatic crossover for all modes *(tse + 0xB0) = *(tse + 0xB0) | 0x0060; // Write to register 20 of the PHY chip for Ethernet port 2 to set up delay for input/output clk *(tse + 0xB4) = *(tse + 0xB4) | 0x0082; // Software reset the second PHY chip and wait *(tse + 0xA0) = *(tse + 0xA0) | 0x8000; while (*(tse + 0xA0) & 0x8000) ; // Enable read and write transfers, gigabit Ethernet operation, and CRC forwarding *(tse + 2) = *(tse + 2) | 0x0000004B; can anybody please clarify me?
