13 years agoGigabit Ethernet Interface (via Marvell 88E1111) with Cyclone IVE FPGA
Hello Everybody, I am using Altera DE2-115 Board (CyloneIVE device) and want to connect some other device running in Gbps via its Gigabit Ethernet Transceiver (Marvell 88E1111) interface. ...
12 years agoBecause people often want to use a NIOS along side the Ethernet, it sometimes makes sense to purchase the IPS-EMBEDDED bundle:
http://www.altera.com/devices/processor/nios2/ipsuite/ni2-ip-suite.html As far as licensing terms go, every IP we have purchased has had perpetual use with 1 year of updates. Regarding doing everything in HDL, see the UDP Offload example: http://www.alterawiki.com/wiki/nios_ii_udp_offload_example You can start with a scheme like that and then hardcode / trim down everything to get rid of the NIOS + software if you are working with a closed system (e.g. you just want a point-to-point link to broadcast/receive streaming data between two boards using Ethernet as the transport).
