13 years agoGigabit Ethernet Interface (via Marvell 88E1111) with Cyclone IVE FPGA
Hello Everybody, I am using Altera DE2-115 Board (CyloneIVE device) and want to connect some other device running in Gbps via its Gigabit Ethernet Transceiver (Marvell 88E1111) interface. ...
12 years agoWhen you compile the project, in the report go to Analysis & Synthesis > IP Cores Summary, and you will see a list of all the licensed IPs. That way you can see which ones you need.
You'll probably need at least the TSE core for Ethernet, the Nios CPU if you aren't using the /e version, and maybe a memory controller. For the prices you should contact your local distributor for a proposal. In some cases they have packages with licenses for several IPs at a reduced price.
