13 years agoGigabit Ethernet Interface (via Marvell 88E1111) with Cyclone IVE FPGA
Hello Everybody, I am using Altera DE2-115 Board (CyloneIVE device) and want to connect some other device running in Gbps via its Gigabit Ethernet Transceiver (Marvell 88E1111) interface. ...
12 years agoHi,
I am following the tutorial "using Triple speed Ethernet" and programmable file it generated is ...._time_limited.sof. I am able to run it on the board via JTAG. Now, I wanted to flash the board in Active serial mode and getting following popup window: some devices in current device list cannot be added to selected programming mode active serial programming? do you want to clear all devices in current device list and switch to selected mode. Beside this, there is also no .pof file generated to flash the board in active serial mode. I know this is some kind of licence limitation. I would like to flash the board with Hardware configuration file(.pof) and run application software program(C file) on it in active serial mode (standalone mode) to fulfill complete Gigabit Ethernet Implementation. My question is: Which licence is exactly needed and how much approximately does it cost?
