13 years agoGigabit Ethernet Interface (via Marvell 88E1111) with Cyclone IVE FPGA
Hello Everybody, I am using Altera DE2-115 Board (CyloneIVE device) and want to connect some other device running in Gbps via its Gigabit Ethernet Transceiver (Marvell 88E1111) interface. ...
12 years agoIf the EPCS is the only flash you have on the board, you can boot from it if you have enough space left in it.
http://www.altera.com/literature/an/an458.pdf
