13 years agoGigabit Ethernet Interface (via Marvell 88E1111) with Cyclone IVE FPGA
Hello Everybody, I am using Altera DE2-115 Board (CyloneIVE device) and want to connect some other device running in Gbps via its Gigabit Ethernet Transceiver (Marvell 88E1111) interface. ...
13 years agoHi Daixiwen,
Here I just want to add IP and UDP header on the Raw Ethernet frame. The Ethernet is working at 760 Mbps with Raw data. I edited the code as you suggested but not getting the desired result. Could you please have a look on the code (attachment) to find where is the mistake?
