13 years agoGigabit Ethernet Interface (via Marvell 88E1111) with Cyclone IVE FPGA
Hello Everybody, I am using Altera DE2-115 Board (CyloneIVE device) and want to connect some other device running in Gbps via its Gigabit Ethernet Transceiver (Marvell 88E1111) interface. ...
13 years agoHi,
The ethernet transmit frame after changing the original code to ether type IP is: unsigned char tx_frame[1024] = { 0x00,0x00, // for 32-bit alignment 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, // destination address (broadcast) 0x01,0x60,0x6E,0x11,0x02,0x0F, // source address 0x08,0x00, // length or type of the payload data '\0' // payload data (ended with termination character) }; According to some internet source: // The packet length# define PCKT_LEN 1024 // The IP header's structure struct ipheader { unsigned char iph_ihl:5, iph_ver:4; unsigned char iph_tos; unsigned short int iph_len; unsigned short int iph_ident; unsigned char iph_flag; unsigned short int iph_offset; unsigned char iph_ttl; unsigned char iph_protocol; unsigned short int iph_chksum; unsigned int iph_sourceip; unsigned int iph_destip; }; // UDP header's structure struct udpheader { unsigned short int udph_srcport; unsigned short int udph_destport; unsigned short int udph_len; unsigned short int udph_chksum; }; // The checksum unsigned short csum(unsigned short *buf, int nwords) { // unsigned long sum; for(sum=0; nwords>0; nwords--) sum += *buf++; sum = (sum >> 16) + (sum &0xffff); sum += (sum >> 16); return (unsigned short)(~sum); } char buffer[PCKT_LEN]; // Our own headers' structures struct ipheader *ip; struct udpheader *udp; // Fabricate the IP header or we can use the // standard header structures but assign our own values. ip->iph_ihl = 5; ip->iph_ver = 4; ip->iph_tos = 16; // Low delay ip->iph_len = sizeof(struct ipheader) + sizeof(struct udpheader); //ip->iph_ident = htons(54321); ip->iph_ident = 54321; ip->iph_ttl = 64; // hops ip->iph_protocol = 17; // UDP // Source IP address, can use spoofed address here!!! ip->iph_sourceip = 0xa074; // The destination IP address ip->iph_destip = 0xa073; // Fabricate the UDP header. Source port number, redundant udp->udph_srcport = 0x80; // Destination port number udp->udph_destport = 0x70; udp->udph_len = sizeof(struct udpheader); // Calculate the checksum for integrity ip->iph_chksum = csum((unsigned short *)buffer, sizeof(struct ipheader) + sizeof(struct udpheader)); memcpy(buffer,&ip, sizeof(ip)); memcpy((buffer+ sizeof(ip)),&udp, sizeof(udp)); Now I am wondering how I can add this IP and UDP header to the raw data. I mean there is no any socket number or something like that. So where I have to map the variable buffer now? Is it to change some parameters here(below) in original code? If yes, how? If not what is alternative? // Create transmit sgdma descriptor alt_avalon_sgdma_construct_mem_to_stream_desc( &tx_descriptor, &tx_descriptor_end, tx_frame, 1480, 0, 1, 1, 0 ); // Set up non-blocking transfer of sgdma transmit descriptor alt_avalon_sgdma_do_async_transfer( sgdma_tx_dev, &tx_descriptor ); // Wait until transmit descriptor transfer is complete while (alt_avalon_sgdma_check_descriptor_status(&tx_descriptor) != 0) ; } return 0; }
