13 years agoGigabit Ethernet Interface (via Marvell 88E1111) with Cyclone IVE FPGA
Hello Everybody, I am using Altera DE2-115 Board (CyloneIVE device) and want to connect some other device running in Gbps via its Gigabit Ethernet Transceiver (Marvell 88E1111) interface. ...
13 years ago --- Quote Start --- Can't you generate the application from the Nios Console instead? --- Quote End --- Hi Daixiwen, Is that mean to check the application with "Nios II 12.1 Software Build Tools for Eclipse" software instead of "Altera Monitor Program" software?
