13 years agoGigabit Ethernet Interface (via Marvell 88E1111) with Cyclone IVE FPGA
Hello Everybody, I am using Altera DE2-115 Board (CyloneIVE device) and want to connect some other device running in Gbps via its Gigabit Ethernet Transceiver (Marvell 88E1111) interface. ...
13 years agoIt looks like the problem lies in the Altera monitor then, form what I am seeing you can use nios2-app-generate-makefile from the Nios command shell.
Unfortunately I don't have that monitor so I can run any tests. Can't you generate the application from the Nios Console instead?
