13 years agoGigabit Ethernet Interface (via Marvell 88E1111) with Cyclone IVE FPGA
Hello Everybody, I am using Altera DE2-115 Board (CyloneIVE device) and want to connect some other device running in Gbps via its Gigabit Ethernet Transceiver (Marvell 88E1111) interface. ...
13 years agoHi,
Sorry but I am not much familiar with FPGA environment and actually I didn't understand exactly what you mean. I am applying the software part of that tutorial in Altera Monitor Program software running in windows XP 64 bit and getting that error. I am not sure this is what you mean but I checked like this from start menu\allprogram\Nios II EDS\Nios2 Command Shell and it shows: ------------------------------------------------ Altera Nios2 Command Shell [GCC 4] Version 12.1, Build 177 ------------------------------------------------ Administrator@..../cygdrive/c/altera/12.1 $ when I use here the command: echo $PATH the output is: ------------------------------------------------ Altera Nios2 Command Shell [GCC 4] Version 12.1, Build 177 ------------------------------------------------ Administrator@.... /cygdrive/c/altera/12.1 $ echo $path Administrator@.... /cygdrive/c/altera/12.1 $ and didn't get like: /cygdrive/*/altera/*/nios2eds/sdk2/bin
