13 years agoGigabit Ethernet Interface (via Marvell 88E1111) with Cyclone IVE FPGA
Hello Everybody, I am using Altera DE2-115 Board (CyloneIVE device) and want to connect some other device running in Gbps via its Gigabit Ethernet Transceiver (Marvell 88E1111) interface. ...
13 years agoIt could be a problem in your Cygwin installation. Are you doing this from the Nios II command shell? Could you check the value of your PATH environment variable (echo $PATH in the Nios II command shell) and check that you have /cygdrive/*/altera/*/nios2eds/sdk2/bin in it?
