13 years agoGigabit Ethernet Interface (via Marvell 88E1111) with Cyclone IVE FPGA
Hello Everybody, I am using Altera DE2-115 Board (CyloneIVE device) and want to connect some other device running in Gbps via its Gigabit Ethernet Transceiver (Marvell 88E1111) interface. ...
13 years agoHi,
I am getting following error while using Altera Monitor Program to apply above tutorial: usr\bin\bash nios2-app-generate-makefile: command not found I looked on some post, they say NIOS IDE should be installed in the directory without space. I already have both nios IDE and Quartus installed in the directory without space. The project directory is also without space. what could be problem then?
