13 years agoGigabit Ethernet Interface (via Marvell 88E1111) with Cyclone IVE FPGA
Hello Everybody, I am using Altera DE2-115 Board (CyloneIVE device) and want to connect some other device running in Gbps via its Gigabit Ethernet Transceiver (Marvell 88E1111) interface. ...
13 years ago --- Quote Start --- Are you using a development kit? If so you should already have an example design with the TSE Mac that you can look at. --- Quote End --- Yes, I am using Development kit (DE2-115 having Cyclone IVE device) and it has the Marvell PHY (88E1111). I couldn't find an example design with the TSE Mac in the provided CD. Instead I found "10_100_1000 Mbps Tri-mode Ethernet MAC" which also uses Marvell PHY (88E1111) and written in verilog on Opencores.org but I don't know how to use it. can I get some idea how to proceed?
