11 years agoGetting Slow Frame Rate using Frame Buffer Driver on Cyclone IV Board
Hi, I am developing Frame Buffer based Video Driver to Play upto 720P Resolution Video on Cyclone IV board in Linux Platform. I have used concept of Linux PCI Driver as well as Virtual Frame ...
11 years agoHi,
--- Quote Start --- Yes. I am getting Proper Image but getting video as slow compare to its actual time for high resolution supported video like 720P. --- Quote End --- It seems that the data transfer from DDR2 to VGA master module via FIFO buffer is working well. But its maximum peak data transfer rate reaches 75MHz x 8byte = 600MByte/sec. Whereas, the DDR2 <-> FPGA peak rate is 125MHz x 2 x 8byte lane ? = 2GByte/sec, You have the room 2Gbyte - 0.6Gbyte = 1.2Gbyte, but this is a theoretical rate. So I recommend you that once check the data transfer between your PCIe and DDR2, by using Signal TapII, etc. Kazu
