12 years agoGetting Nios to talk to on chip logic
Total newbie question but what is the best way to get Nios to talk to custom on chip logic ? I'm setting up a special counter in logic that I'd like to have Nios control and read. Do I need to set up...
12 years agoYou need to access the logic via the avalon bus.
I think you can use a generic 'pio' interface, but writing a avalon slave isn't that hard and will give greater flexibility (and probably remove some clock delays). Do make sure you generate a 32bit slave - even if you ignore the high bytes. Also the nios always asserts all 4 byte enables on reads.
