16 years agoGet stack top/bottom pointers at run time?
Hi folks- I want to write a stack test function to detemine stack usage during run time testing. For that I need to be able to get stack top and bottom pointers at run time. Can anyone p...
16 years agoThere's already a feature that does this... See attached image from the BSP Editor. There is a similar option in the Nios II IDE's Syslib configuration stuff. The actual compile-time changes are mentioned in the attached image, as well.
Cheers, -slacker
