14 years agoGet image from frame
I am working on a project and need to process image frames acquainted before it goes to display. From the VIP Camera example, I found this: display = alt_video_display_only_frame_init(// ALT_VI...
14 years ago --- Quote Start --- Check: http://www.altera.com/literature/an/an527.pdf (http://www.altera.com/literature/an/an527.pdf) All of the functions (as far as I can tell) are listed there as well as descriptions for each function. --- Quote End --- Thank You for the link. It was certainly helpful but I still quite confuse with this function: ======== int alt_video_display_buffer_is_available(alt_video_display* display); This function returns the next free frame buffer available for display. The function returns a condition code of 0 if an empty buffer is found; any other return value indicates failure. The function accepts the following parameter: ■ display: This variable is a pointer to a data structure that keeps track of all of the frame buffer information, including the start addresses for all of the frame buffers. ======== It says that it return 0 or other number indicates failure. Then, my question is, where is the frame I want goes? I need the frame to do analysis before display. Thank you.
