22 years agoGERMS in NIOS2?
Hi people. How do I use the germs monitor in NIOS 2???? In NIOS 1 I could just check in SOPC builder that I wanted to embed a germsmonitor. How is this done now??? I want to call the germs ...
22 years agoThe IDE is definitely the way to go for downloading code.
However, if you still want to use germs, it is still there. Add a legacy on-chip memory component (in SOPC Builder under legacy components). This is the old memory component you are familiar with that has a contents tab that lets you select germs. In the "More CPU" settings page of SOPC Builder, make sure you point your reset address to the start of the germs memory and set the debug device to one of your uarts. Also, you might need to enable legacy SDK on the same page. I'm not sure about this so try it without first.
