16 years agoGerber Files
Would somebody please direct me to a forum that knows about Gerber files... BAK Backup file for PCB layout BMK Bottom mask gerber file BOT Bottom layer gerber file BPS Bottom past...
16 years agoThanks for your reply... Why do they have to compile this PCB ...
don't understand that one... Does Gerber have a PCB file??? I should look into the makeup of a PCB... How long have you been using Quartus by the way ???? Does it do the job ??? Would a motherboard designer even use this software ??? What documents do they send to the guy who makes the board???? Output from what software.... I thought the guy who makes the boards only gets Gerber... So, Altera is only one small piece of the puzzle... The company who etches the electronic circuity in copper, what documents does he use ???? Have you ever had a board designed and made ??? thanks for your time... I just need toknow what I have to send to the final guy who puts all the components together... Getting confused in the process...
