16 years agogenext2fs: couldn't allocate a block (no free space)
Hi all, I had a working mmu linux, but after adding few more modules, the make fails. What could be the solution ? (my hard disk isn't full :)) Thanks. make image.rootfs.all
make...
16 years agoThank you Slacker.
It sounds good to increase the size of this, but I've looked for the definition place of this parameter: I found that it is defined in uClinux-dist/user/Kconfig: config USER_RAMIMAGE_RAMFS8192 bool "8192K" There is other choices from 64k up to 8192k, but no more ! So is it really possible to increase that ? Anyway I find an alternative solution in removing "cxx c++ test apps" from the build (saves about 1 500k !)
