21 years agoGenerating Filesystem for EP2S60 DSPBoard fails
Hi to all. I have a DSP Board (STRATIX II) from Altera. No there is a problem by generating the Filesystem in the NIOS II IDE. In the "Target Filesystem Application Selection" the bottom line sa...
21 years agoHi all,
I've encountered the same problem as Mabcom here, regarding the Stratix II DSP Development Board. I left a PM with Ken, but figured I'd post here to cover all my bases. When trying to create the filesystem I encounter the same error: "Total amountof memory available: 0K" Looking into my PTF I encounter some configurations that I am unfamiliar with. I'll append a snippet of that section at the bottom. I am unsure where the page0-page2 configs are originating. I would like to figure this out, so I may dedicate a section in memory to the filesystem. This would allow me to continue on with Ken's command line generate and upload suggestion. On another note, I tried briefly to build the system in the command line, as far as I could go without having to dictate memory space for the filesystem. I encounter the following error regarding the romfs generate command (where filesystem_2s60 is the name of my project): [SOPC Builder]$ genromfs -d -V "filesystem_2s60" -f romfs.bin -v genromfs: you must specify the destination file Try `genromfs -h' for more information Any suggestions as to either of these issues? Thanks much. CONFIGURATION factory { length = ""; menu_position = "4"; offset = "0x00200000"; reference_designator = "U17"; } CONFIGURATION page0 { length = ""; menu_position = "1"; offset = "0x00500000"; reference_designator = "U17"; } CONFIGURATION page1 { length = ""; menu_position = "2"; offset = "0x00800000"; reference_designator = "U17"; } CONFIGURATION page2 { length = ""; menu_position = "3"; offset = "0x00c00000"; reference_designator = "U17"; }
