21 years agoGenerating Filesystem for EP2S60 DSPBoard fails
Hi to all. I have a DSP Board (STRATIX II) from Altera. No there is a problem by generating the Filesystem in the NIOS II IDE. In the "Target Filesystem Application Selection" the bottom line sa...
21 years agoHi Marco, I'll work on getting you a patch that will let you do what you need. In the meantime, you can create your filesystem from the IDE but you will need to perform the build and the upload from the commandline:
To build your filesystem: [SOPC Builder]$ cd $ECLIPSE_WORKSPACE/<project> [SOPC Builder]$ genromfs -d -V "<project>" -f romfs.bin -v [SOPC Builder]$ bin2flash --input=romfs.bin --base=<base address of flash> --output=romfs.flash --location=0x800000 To upload your filesystem: [SOPC Builder]$ cd $ECLIPSE_WORKSPACE/<project> [SOPC Builder]$ nios2-flash-programmer --input=romfs.flash --sof=<flash programming sof> --base=<base address of flash> In the above steps, the <flash programming sof> file that I'm referencing is: ...altera/kits/nios2/components/StratixII_Marco/system/StratixII_Marco.sof or something like that. The <base address of flash> can be found in the PTF file for the above SOF file.
