21 years agoGenerating Filesystem for EP2S60 DSPBoard fails
Hi to all. I have a DSP Board (STRATIX II) from Altera. No there is a problem by generating the Filesystem in the NIOS II IDE. In the "Target Filesystem Application Selection" the bottom line sa...
21 years agoI saw your PTF file, are you using a custom board?
Here's what I thought I saw: (1) User Configuration starts at 0x200000 (2) Factory Configuration starts at 0x500000 The kernel currently uses the first 2 megs of memory (0x0 -> 0x200000). The filesystem normally starts at 0x200000 until the first configuration found. In your case, that means a 0 length filesystem. Do you have any free space *after* the user and factory configurations in flash? If you do then I'll need to create a patch for you. It currently assumes that factory configurations are normally at the end of flash.
