19 years agogdb-server can't find Cyclone II board
I'm trying to connect to a Cyclone II board using jtagd and nios2-gdb-server-wrapped under Linux. They seem to find the USBBlaster OK -- the blue LED flashes briefly when I start the gdb-serve...
19 years ago --- Quote Start --- originally posted by hippo@Oct 30 2006, 08:16 PM would you please add a page on nios wiki to describe how to setup the gdb server?
that would be very helpful. http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/smile.gif --- Quote End --- Done: http://nioswiki.jot.com/wikihome/linuxgdbserver (http://nioswiki.jot.com/wikihome/linuxgdbserver) I see that we're encouranged to "sign our work" on the Wiki, but I've no clue what that means or how to do it. FWIW, my privilege problem was due to the fact that I forgot to make /etc/hotplug/usb/usbblaster executable. Making jtagd suid root didn't work because suid executables ignore the LD_LIBRARY_PATH environment variable.
