20 years agoGDB HOST on Nios?
I'm wanting to experiment with some remote debugging ideas. To this end I was wondering if anyone had tried to setup a GDB host on a NIOS processor. I've looked at the GDB porting documentation and it looks like it may be possible. I was just wondering if anyone one else had tried this crazy idea. Thanks for any insight.4 Replies
Ummmm....that's how the current, Altera-supplied debug solution works. The Eclipse-based IDE communicates through GDB and the Insight debugger is shipped with every release. In fact, the whole of the toolchain is GNU/GCC/GDB based.
How would your port be any different? :-) Cheers, - slacker - Altera_Forum
--- Quote Start --- originally posted by slacker@Aug 9 2006, 04:57 PM ummmm....that's how the current, altera-supplied debug solution works. the eclipse-based ide communicates through gdb and the insight debugger is shipped with every release. in fact, the whole of the toolchain is gnu/gcc/gdb based.how would your port be any different? :-)
cheers,
- slacker
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17481)
--- quote end ---
--- Quote End --- How Insight can be launched ? Thx.
--- Quote Start --- originally posted by slacker@Aug 9 2006, 05:57 PM how would your port be any different? :-) --- Quote End --- Hi, Just to be clear here, I want the 'HOST' to reside on the NIOS to communicate with other 'TARGET's. You can, for instance, do this with the ARM processors (among others). In fact, one of the options is for an ARM-uclinux configuration. This is why I think it may be possible on the NIOS/uCLinux combination. Unless I'm mistaken the 'HOST' for a typical NIOS development cycle is the x86 PC. Thanks! - Altera_Forum
Ok... sorry, I misunderstood you.
Good luck! - slacker
