20 years agogdb and daig_printf()
Is it possible to use jtag_uart with gdb, i.e. I want to use gdb via nios2-gdb-server --tcpport=2343 and still use diag_printf over the same jtag port. It looks like it should be possible in the config by setting CYGSEM_HAL_DIAG_MANGLER to gdb and CYGDBG_HAL_DIAG_TO_DEBUG_CHAN to True.
Whatever combination I use fails to work, I might be something to do with my app not starting when I use diag_printf() until I run nios2-terminal Help! Thanks Robert.2 Replies
simply start two shells, on one start nios2-gdb-server and on the other start nios2-terminal. The jtag_uart is indeed blocking: if you don't have the nios2-terminal running, the application blocks in the diag_printf call. Regards, Andreas. - Altera_Forum
Great, this worked, I was trying to get the output into insight, but this will do just fine.
I disabled mangling, for what it's worth. Thanks. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif Robert.
