15 years agoGcc4 Frame Pointer Issue
I've been trying to write some code in an MPU exception handler to trap and dump the call stack when an intermittent exception occurs in our system and am pretty sure I've found a bug in the latest G...
12 years agoIf anyone's interested we use the following function to dump the stack of a UCOS thread, should be fairly straght forward to modify for none UCOS systems:
// these variables generate by linker, using standard linker script.
extern char _start;
extern char __etext;
extern char __ram_exceptions_start;
extern char __ram_exceptions_end;
void DumpStackTcb(OS_TCB* a_pTCB)
void* sp = 0;
//lint -e{522}
__asm ("mov %0, sp" : "=r" (sp) );
void* pTextStart = &_start;
void* pTextEnd = &__etext;
void* pExceptStart = &__ram_exceptions_start;
void* pExceptEnd = &__ram_exceptions_end;
OS_STK* pStackBottom = a_pTCB->OSTCBStkBottom;
OS_STK* pStackTop = a_pTCB->OSTCBStkBottom + a_pTCB->OSTCBStkSize ; // OSTCBStkSize is num of elements, not bytes
OS_STK* pStackCur = a_pTCB->OSTCBStkPtr;
isr_printf("TS(0x%x) TE(0x%x) ES(0x%x) EE(0x%x)\n", (unsigned)pTextStart, (unsigned)pTextEnd, (unsigned)pExceptStart, (unsigned)pExceptEnd);
isr_printf("id(0x%x) sb(0x%x) st(0x%x) ss(0x%x) sp(0x%x) sp(0x%x)\n"
, a_pTCB->OSTCBPrio
, (unsigned)pStackBottom
, (unsigned)pStackTop
, a_pTCB->OSTCBStkSize * sizeof(OS_STK)
, (unsigned)pStackCur
, (unsigned)sp
u32 Cnt = 0;
for(OS_STK* pStack = pStackCur; (pStack >= pStackBottom) && (pStack < pStackTop) ; pStack++) {
void* pPossibleAddr = (void*)*pStack;
if(((((unsigned)pPossibleAddr) & 0x3) == 0) &&
(((pPossibleAddr > pTextStart) && (pPossibleAddr <= pTextEnd)) ||
((pPossibleAddr > pExceptStart) && (pPossibleAddr <= pExceptEnd)))) {
u32 PrevInstr = *((OS_STK*)pPossibleAddr-1); // check if instruction before poss. return address is a call
if( ((PrevInstr & 0x3f) == 0) || ((PrevInstr & 0x07ffffff) == 0x003ee83a) ) { // check call / callr
isr_printf("0x%x: ra(0x%x) pi(0x%x)\n", Cnt, (unsigned)pPossibleAddr, PrevInstr);
Cnt++;
