15 years agoGCC 4.1.2 Issue. New toolchain soon?
I'm running into a bug where the following code causes a compiler error: class foo {
public:
virtual const char* name() const throw();
virtual const char* faux_name() const th...
13 years agoThe functions are marled 'inline' as well.
However, even though they are static and only called once minor changes would stop the functions being inlined. --- Quote Start --- 5a) I'd arranged for my nios data areas and the 'small io' to be within a 64k block (to get gp relative addressing for everything), but I'd missed a trick! I should have put the 'small io' below 0x7fff - then it could be accessed by offsets from r0. It would be nice if gcc supported such variables - probably need a gcc attribute (or a special section - attribute is probably cleaner). --- Quote End --- Actually I wonder if the linker could modify the instruction to use r0 instead of gp if the offset from gp is out of range but a valid offset from r0? There is a specific error message so there must be some specific code.
